Hi Expert,
Our customer read "TPS1HC100-Q1 Functional Safety" and they have some question.
Question 1:
What's the relationship between (FIT) Rates and Failure Mode Distribution (FMD) and Pin Failure Mode Analysis (Pin FMA). Are are correlated?
In (FIT) Rates part, there are two kinds, Die FIT and package FIT. But later in Failure Mode Distribution (FMD) part and Pin Failure Mode Analysis (Pin FMA) , the customer think FMD is related with Die FIT rate and Pin FMA is related with package FIT. But here is one question, if so, package FIT should contains more besides Pin.
May you help explain their relations? Thanks.
Question 2:
In particular, do we have failure mode of short-circuit to ground and the corresponding failure rate information regarding Vbb pin?
BR,
Elec Cheng
