Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
UCD8220: Using UCD8220 without feedback
Part Number: UCD8220
Other Parts Discussed in Thread: LM5030
Hello, I am looking for a push pull transformer driver IC without any control mode (Voltage mode or current mode) Basically I just need to send the PWM signal using a Microcontroller and get the complementary signals for the
External Transistors that are going to drive the transformer.
My question is can I use UCD8220 while leaving the CTRL pin 6 floating or pulled up since I am not going to use the feedback? or I need a different IC with another part number that doesn't include a feedback. If so can you please recommend part numbers from TI.
Thank you very much in advance.
BR
Amr Wael
