Hi Team,
Good day! I am posting this in behalf of the customer. Kindl please help.
I would like to use the part DCR022405 for a design that has a very critical board height and with clearance. I need some help with your 3d model. I am building the part manually in eaglecad, but your 3d model width span doesn't fit my pads. I was wondering if it is possible to have someone verify the model to determine if the width span on the 3d model is correct.
This is the model. My pad width is 7.63mm (~0.0393701")
The verification of the with will help me determine if I can use this part to replace a dc/dc converter in a really tight spot within the enclosure
I look forward to hearing from you.
Jonathan
