I am designing a power Mux for our water pump which should be powered up with 8V only at the start up of the device and after 20us we should switch it to 5V.
Therefore the use of TPS2120, so the microcontroller can select the power rail needed (PUMP_SEL).
I would like to share with you the design in case there is anything to be improved :) I appreciate your help!
Sabrine
