LM5046: Huge reflection Power Supply spikes when Board is inserted
Part Number: LM5046
Other Parts Discussed in Thread: TPS2393, LM5064
We are having issues with new hotplug used on latest board developments. Customer has complained that when they insert one board in the chassis, other boards already inserted are affected ( Board resets ). We didn’t saw that issue in “old” boards.
New boards are equipped with: LM5064PMHE/NOPB
Old boards are equipped with: TPS2393APW
We have been doing a lot of different tests past   weeks but we are not able to find the issue, neither to improve results. We have noticed that a huge spike is generated when we insert the board which affects the other boards on the rack. That spike has a smaller slope in Old hotPlug
    The TPS2393 is used for HOTSWAP on the old board, but LM5046 is used for full bridge control. They are completely different, and can't be replaced with each other. Are you sure LM5046 is a right part to be replaced?
    Thanks for quick answer.
    However the title of subject is wrong ( we made a mistake when we have selected PN on the form ). The correct PN is LM5064PMHE/NOPB which is supposed to be also a HOTSWAP.
    So please, could you help us with spikes generated by LM5064 ?  any suggestions ? Any explanations ? Any improvements ?
    Jordi
    Thanks for the clarification. LM5064 is supported by different product engineers. I am not sure who I should forward to. The better way is to restart a new post thread using LM5064. It will go to right engineers to answer your question.
