Part Number: TPS22910A
Other Parts Discussed in Thread: TPS2116
Messrs TI,
I am testing a custom board with two TPS22910A devices that share the same output; this is because each of them manages two different power source for the board (USB 5V_EXT & Battery VBAT).
I attach here the schematic for your reference:
My concern is regarding the output shared by the two TPS22910A because we are facing an issue when the board is powered from battery: it seems that IC7 doesn't output the battery voltage (VBAT) on V_ON net.
Do you have any suggestions for optimizing this design?
Best Regards
