For doing the worst case circuit analysis, I wanted to know the output voltage setpoint corresponding to TRK pin voltage and the Vout deviation.
I found from datasheet that the Vout will be 60*Vtrk and by this way I could find the typical Vout corresponds to the TRK pin voltage in my case.
For example, Vtrk=0.75V, Vout will be 45V. Now my concern is to know how much this typical Vout (45V) will vary because of the tolerance of this controller?
Thanks in advance.
