How do you make the OTA a gain of 1? In SIMPLIS I want to get the response with H(s)=1. Do you put a resistor to ground on the output?
THanks.
THanks.
Hi Knute,
Is this to perform stability analysis?
This Application Note may be useful to you as it shows the main components of the transfer function: Demystifying Type II and Type III Compensators Using OpAmp and OTA for DC/DC Converters
The Error Amplifier transconductance (EAgm) can be altered in the model netlist. I believe this is accessible by pressing F11.
Sarah
I'm not sure I completely understand what your goals are, could you elaborate? The gain of the OTA is the Error Amplifier transconductance (~1800 uA/V nominal value). I don't typically see OTAs used in a follower configuration so I'm not sure I understand what this would achieve. Are you wanting to observe the open loop response?
Sarah
Hey Knute,
We can continue this discussion in our email thread, but see the following recommendation from our design team:
If you have any other questions feel free to email me.
Daniel
