[FAQ] TPS2372: What happens when TPS2372-3 is configured as Class 7?
Part Number: TPS2372
Other Parts Discussed in Thread: TPS23730
A family of our products use the TPS2372-4 configured as Class 7. The TPS2372-4 is currently not available. It turns out that many of the product models do not exceed Class 6 power levels so we would like to use TPS2372-3 (which is available) in those models but maintain the Class 7 configuration. Is it only the pass-FET Rds-on, current limit, and inrush current limit which is different between the TPS2372-4 and theTPS2372-3 such that the situation described above will work?
  • Hi Shawn,
    You are right. The main difference between TPS2372-3 and TPS2372-4 are the power rating. Compared to TPS2372-4, the TPS2372-3 has (comparisons based on typical values):
    1. lower power rating (51 W to 71 W)
    2. higher pass FET on-resistance (0.3 Ω to 0.1 Ω)
    3. higher thermal resistance (junction-case 40.2 to 38.0 °C/W)
    4. lower inrush current limitation (200 mA to 335 mA)
    5. lower operation current limitation (1.85 A to 2.2 A)
    6. lower recommended current (1.2 A to 1.85 A)
    The Class 7 is between 51 W to 62 W. When the input voltage of PD is the lowest 37 V, the highest current flow through through PD will be up to 1.68 A and it won't cause current limitation at typical condition.
    So if your product won't exceed Class 6 in most of time and only reach Class 7 very rarely and within a short time, it looks ok for me to use TPS2372-3. While the best solution is to find enough TPS2372-4. I will check when TPS2372-4 will be restocked and let you know.
    Diang
  • Hi Diang,
    Thankyou for the fast reply. So, to be clear, the TPS2372-4 and TPS2372-3 will both negotiate as Class 7 when configured as such, correct?
  • Hi Shawn,
    Yes, both TPS2372-3 and TPS2372-4 should be configured as Class 7 resistor in your case. The negotiation is mainly the PSE send the voltage pulse and read the return current from the PD.
    I currently do not have TPS2372-3, while I tested a TPS23730 which is also rated as Class 6. It can be configured with Class 8 resistor and pass the negotiation:
    Diang
