LM25141-Q1: LM25141 phase margin test method on fix voltage
Part Number: LM25141-Q1
Other Parts Discussed in Thread: LM25141
Here are too states of LM25141, fix and adjustable feedback.
In fix mode, FB is connected to VDDA.
If i want to test the phase margin on fix mode, should i add and adjust the resistance on FB and then carry out the test?
Is there any difference between fix and adjustable feedback? The result would be same?
If not, would you mind sending me the test method on different mode?
Thanks a lot.
