TPS7A8300: TPS7A8300
Part Number: TPS7A8300
Hello there,
Sorry, the part number was wrong in my email eariler. I have a question again.
I have a question about TPS7A8300.
We have to perform the pretest to DVM(digital multi-meter) before SMT work to check the LDO is okay or not.
Can you tell me how to check there is no problem in the TPS7A8300 by using DVM and which pins of LDO I should check?
I'm looking forward to getting your answer ASAP.
  • Jason,
    I don't understand the question. Are you saying that you will probe the pins directly with a multi-meter when it is not soldered on the board? If that is the case, there is no test you can do with a multi-meter that will verify that it is a good device when it is not soldered on a board and powered.
    Nick
