Hi Team,
Hope you are well!
I am planning to use the UC1708-SP to drive a couple of power MOSFETs at 500 kHz in a converter design. The datasheet only has current supply current draw data for a 2200 pF load switching at 200 kHz.
- Are there any concerns with switching this part at 500 kHz?
- Is there any data on total supply current when switching at higher frequencies?
- Can both channels be operated independently such that we could have each channel driving a FET in two separate converters? (i.e. there won’t be any relationship between the switching duty cycle of each channel)
- Is there any SEE data on this part? I do like that it is bipolar, but I still wonder if it has been tested in heavy-ion eve
Thanks!
Connor
