Hi Team,
Could you share the thermal design detail of LMG3422EVM-043? Includes TI GaN's PCB thermal pad size(dimension) and PCB thermal via size(dimension).
My customer would like to leverage the similar design to theirs.
Charles
Hi Team,
Charles
Thank you for reaching out, please give me some time to respond properly to your question. I will talk with my team and give you an answer tomorrow, I will let you know if I need any more details from you.
Zach
Update:
For our LMG3422EVM-043, we use the same thermal pad size and thermal vias that are in the mechanical information of the LMG342xR030 datasheet.
Please see section 14 of the following datasheet link for all dimensions:
https://www.ti.com/lit/gpn/lmg3422r030
One thing to note: in the EVM you referenced, some of the thermal vias on the low-side device are not placed. This is done intentionally to provide a return path for current to flow beneath the device in a signal layer which minimizes parasitic inductances. If you'd like more information about this please let me know and I can elaborate.
Zach
