Other Parts Discussed in Thread: TPS51200, , TPS51200A-Q1
Hi Team
I notice that the DS specifics 10mA of current limit for the VTTREF pin, which is marked as the minimum value.
Do we have the typical and maximum value of this?
Hi Team
David,
I believe that the recommendation is to limit the pin to 10mA of current.
This assessment is based on the "Features" Section on the first page of the datasheet:
Kadeem
David,
Just to provide a little more information : from an FAQ by Qian Chen, 100uA on the reference output is typically enough for most DDR applications: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/670527/faq-tps51206-frequently-asked-questions-and-answers?tisearch=e2e-sitesearch&keymatch=tps51206%20vttref#
Kadeem
Hi Kadeem
I did a test using VLDOIN=1.5V and VTT/VTTREF both 0.75V, while kept increasing the output current.
It seems like the VTTREF current went up to 20mA before the output voltage started to drop.
I aware that current not higher than 10mA would be the requirement for normal function, but my customer would like to know the output limit of the internal op-amp of the VTTREF. Do we have this info?
The test result is shown as below.
VTTREF
Current[mA] Voltage[V]
0.00 0.744
5.00 0.740
6.00 0.739
7.00 0.739
8.00 0.738
9.00 0.738
10.00 0.737
11.00 0.737
12.00 0.736
13.00 0.736
14.00 0.735
15.00 0.735
16.00 0.735
17.00 0.734
18.00 0.734
19.00 0.733
20.00 0.410
21.00 0.000
David,
I took a look at the testing repository for this part, and it looks like it is not tested at currents exceeding +/- 10mA.
As such, we do not recommend using VTTREF on this part for currents exceeding +/- 10mA.
If more VTTREF current is required, the TPS51200 or TPS51200A-Q1 may be better for your design. Note that these are not pin-to-pin with the TPS51206, but if pin 9 can be unused,
Kadeem
