The maximum line regulation of LDO is 7.5mV (TPS745-Q1 Datasheet)
Can the output voltage decrease (from the nominal) due to line regulation?
In the application note: https://www.ti.com/lit/an/slva079/slva079.pdf, it seems to suggest that due to an increase in input voltage, the output voltage can swing either in positive, or negative direction from Nominal 3.3V,
I request this information, for calculating the output voltage tolerance of LDO under worst case conditions.
