Other Parts Discussed in Thread: PMP21529, , UCC25800, PMP
Hi Team,
Good day! We need your help.
Kindy find below the customer problem and please advise.Thank you very much for your support
I had a look at the PMP21529 Test Report: 4-Switch Buck-Boost Bi-directional DC-DC Converter Reference Design.
https://www.ti.com/lit/ug/tidt046/tidt046.pdf
There you use the UCC27211A as a FET driver. For some cases in this report, the driver has to work at 100% duty cycle for the high side FET.
However, when I look into the datasheet of the UCC27211A I do not find anything regarding the maximum duty cycle of the half-bridge driver.
So my question is: which of your gate drivers support 100% duty cycle and what are their maximum switching frequencies?
I would need a half-bridge FET driver that allows 100% duty cycle and 500kHz switching frequency. If you could supply me with some part numbers that are available as well that would be great
Could you provide the schematic used in the previously mentioned PMP21529 Test Report? Also, how do I find out the maximal switching frequency your half bridge gate drivers are capable of?
I'll happily come back if any more questions pop up. Thank you in advance for the support.
Jonathan
