Hi, team
Hope you are doing well!
I have a question about the Vslope of TPS92682-Q1.
There is a calculation formula for Vslope on the datasheet, which only limits the minimum value.
(1)What is the upper limit of Vslope?
I only found this restriction in the datasheet. Are there any other restrictions?
(2)If Vslope is selected larger but not exceeding the upper limit, what impact will it have on the circuit?
Thank you for your support and look forward to your reply!
