Part Number: TPS544B25
Other Parts Discussed in Thread: TPS546B24A, , TPS546C23, TPS543B20
Dear Team,
I would like to ask, the initial chip is applied by pulling down VSET, whether the default values inside the chip, such as undervoltage and overvoltage, will affect my normal use of the output voltage?
I use VSET to connect the resistance to ground, adjust the upper and lower resistance of FB to output my 2.57V,
My question is if the initial chip has default values such as Vmax Vmin output or undervoltage, will these values affect the normal operation of my chip.
Many Thanks
Jimmy
