TPS62902: How to connect FRA for measuring phase margin.
Part Number: TPS62902
My customer wants to measure phase-margin with FRA on "VSET and Internal Voltage Divider" mode of TPS62902.   Could you please let us know where is connected with FRA?   Please advise us.
Thanks and best regards,
M.HATTORI.
  • Hi Hattori-san,
    Is the customer using an EVM to test this?
    To setup for gain and phase plots, an injection resistor (10-50 Ohm) will be connected from Vout to the VOS pin.
    The injection signal will be placed across this resistor. Please check the EVM User's guide for more detail on how to modify the EVM to take these measurements.
    Let me know if this clarifies your question.
    Joseph
