Part Number: BQ27Z561
Note : Continuation of Previous thread link - e2e.ti.com/.../bq27z561-battery-training-procedure-using-bq27z561-fuel-gauge-ic-and-bq-studio
After generating golden image we tested it in ti EVM as well as our development board. Everything is working fine in ti EVM board, we are getting proper voltage, current and percentage data but in our development board we are not getting readings properly. Here i am putting two scenarios and it's outcome.
Please help us to find the solution.
ti EVM = bq27z561EVM - 011, BMS011 Rev A EVM
1) We tested golden image in ti EVM board, everything works fine here.
2) We tested same golden image with our development board, here we are not getting proper readings. FCC,RC and RSOC is getting reduced continuously. When we power up the board, everything is good. But after 1-2 seconds FCC jumps to around 1000mAH from 3000mAH/Actual capacity and RC jumps to around 900mAH then it's getting reduced continuously. We tried below things to find the solution.
I - We used ti EVM fuel gauge (bypassed microcontroller of ti EVM) with our development board (bypassed fuel gauge section of our development board), everything works fine.
II - We used ti EVM microcontroller (bypassed fuel gauge section of ti EVM, only used microcontroller of ti EVM) with fuel gauge of our development board, here we are getting this problem.
III - We used only discrete circuit (Rsense section) of ti EVM instead of our development board (bypassed Rsense section of our development board). We just used gauge IC of our development board with discrete/Rsense circuit of ti EVM and here we are also getting problem.
Here i am attaching logs for your better understanding.
Parth
