Part Number: CSD16301Q2
Other Parts Discussed in Thread: TINA-TI,
I want to set LED bias voltage (VLED = Va - Vk) to 2.5V and define the values which signal plays around 2.5V by 400mVpp. But if I increase the Gate voltage, the voltage will increase on R4 which increases the power consumption. How can I fix it without facing the nonlinerity issue of the MOSFET? Should I change the transistor?
VS is fixed to 4.1-4.2V
Thank you
