Other Parts Discussed in Thread: TPS7A20
HI, TI expert
LP5907 datasheet require Cout max is 10uf, but in micro MCU need 22uf for supply , if 22uf used, is it stable or not , how impact on with 22uf
Hi Liu,
I don't have any data for COUT outside of the specified range, so I don't know how the device will behave with larger COUT.
Have you considered TPS7A20? As far as I can tell without knowing your application requirements, this device is specified for at least the same operating conditions, is P2P with the DBV package LP5907, has a much higher maximum COUT, and is also cheaper. If you're not using the DBV package, maybe I can find another P2P device.
Nick
