I fear that in the two examples provided in the documentation the formula to calculate Ron is wrong: Vin should be used in place of Vo. Is my assumption correct?
Could you please check?
Thank you
Thank you
hello Massimo
I've double checked the formula, and this should be right. Pls see my derivation below:
first of all, based on buck topology, the output voltage should be Vo=Vin* D=Vin*ton/Tsw=Vin*ton*fsw.
based on Equation 1, ton=1.34*10^-10*Ron/Vin, we substitute this into formula above and rearrange to get Ron=Vo/(1.34*10^-10*fsw).
I will close this thread if no more questions.
Yes please, I found that a faulty component brought me on the wrong way. Thank you for your attention.
