Hi Team,
Just want to check on conditions to trigger rst_Vout fault.
To my understanding, if RESET pin is triggered, it will report such fault. But is there other conditions? Thanks.
BRs
Given
Hi Team,
BRs
Given
Hi Given,
RST_VOUT is only triggered by the reset pin.
Travis
Hi Travis,
Thanks for your reply. It matches my understanding.
But in customer's application, RESET is pulled to high directly to disable this function, but they still see RST_Vout fault which is strange. Will PMBUS do reset although I didn't see there is reset bit but maybe other fault trigger reset?
Thanks.
BRs
Given
Hi Given,
Are they seeing RST_Vout continuously raised? Also, have you tried clearing faults in Fusion?
Additionally, cycling the enable pin / control bit can sometimes clear weird behavior.
Travis
Hi Given,
I'm closing this thread due to inactivity. To reopen the thread, reply to this post.
Travis
