Hi team,
Here's an issue from the customer may need your help:
Use the gauge to do a 4-string protection board. Shorted 4 and 5 strings. When power is applied, the alert pin reports an undervoltage error. But the voltage capture shows that all four strings of voltage are good.
The 4-string software logic is the same as the 5-string (just the fifth one is not captured). What else does the software need to do?
Could you help check this case? Thanks.
Cherry
