Hello Sir:
Please help to check our log file.
Our SOC from 9% drops to 0%.
Would you please provide some recommendations for us and teach us how to solve this issue?
Looking forward your feedback.
Thanks a lot.
Hello Sir:
Thanks a lot.
Hi Shirish:
Yes, they have been programmed the chemistry ID.
This battery pack has been mass production.
According their log file and gg file, I think that dsg threshold and relax threshold are not right.
Would you please help to check their gg file and provide recommendations?
Thanks a lot.
Hello Statham,
You are right on the Dsg threshold. There is a discharge at below -60 (dsg threshold) for long periods, so that definitely needs to be updated.
Load Select /Load mode is set to present average discharge power. The load is varying. In the log, i see that RemCap drops to zero after current suddenly rises from -56 to -650 (Line 17862). The capacity of the battery is different for different loads. The sudden change in load results in recomputation based on load select/load mode and it correctly drops to 0 because the present average discharge power changed.
To avoid this set Load Select to be closer to the higher side of the varying load. Value of 7 will be suited of the load profile is similar in all discharges. A value of 6 will allow setting a custom load. If the load is unpredictable, then always go with the highest possible User rate.
