another Question regarding TPS7A78:
Is it possible to bridge Charge-Pump? Or asked in another way:
Can I provide external Input-Voltage for VLDOIN and what is the highest voltage I can apply?
I want to use the Voltage of VSCIN for supply of VLDOIN if it falls under 14 Volts...then i still can generate 3.3Volts from VSCIN...
or to change the Switch-Cap Stage from factor 4 to factor 2...is this possible?
