I'm reading SLVA789 article.
In "Typical Application for Voltage-Tacking LDO" part.
"it is necessary to keep the voltage-tracking tolerance between the off-board sensors power supply and the MCU/ADC power supply to the lowest level"
But if we remove the voltage-tracking LDO, and we use one DC/DC or LDO to power both ADC and off-board sensor, the voltage should be identical, the voltage difference should be even smaller?
