TPS3710: RP Value
Part Number: TPS3710
Hi Team,
Can you confirm if the value calculated for RP is correct?
VPU - 3.3V
Detection voltage - 3.3V (sense pin)
OUT is connected to Hi-Z (FPGA input)
OUT (Output sink current) - 40mA
=> RP =10 kohm (33uA)
Additional questions:
What is the parameters for VHI? What is the device standard value.
Also, what is the parameters of the IO?
Thanks in advance.
Marvin
  • Hi Marvin
     You can derive VOH spec of the device from VIH of FPGA.
    VIH will decide the upper limit on RPU.
    (VPU - VIH_FPGA)/ ILKG(od)  >= RPU
    VOL (250mV) of the device is defined at IOL (for given VDD) {it should be less than VIL of FPGA}
    This will decide the lower limit pf RPU
    RPU > ( VPU - VOL )/ IOL
    Trailokya
