My customer has a problem that the output of the TPS40422 CH2 below does not operate normally during production.
Failure symptom is as follows.
1. A drop in the 5V output voltage of Phase 2 occurred in some parts.
2. When they reduced the 5V load this symptom did not occur. However, the actual load was about 10A, which was sufficient for the design.
3. When resistor R20 was removed, Hiccup symptom occurred.
4. When the resistance of R20 was changed to 4.7kΩ, the same symptom occurred.
5. When the resistance of R20 was changed to 1kΩ, this symptom did not occur.
Q1. Is it okay to use 1KΩ as the resistor value for R20? Are there any other recommended values for R20?
Q2. Can they use a value lower than 1KΩ for R20? What are the acceptable MIN values?
Thank you.
JH
