i am using the IC TPS3808G01MDBVTEP. At verification power-up i noted a 300µs low level glich on pin CT whenn VCC reaches nearly 5V.
SNS is adjusted to be triggerd at 4,46V. i assume this glich happens wenn VCC reaches this threshold. CT is tied to VCC via 64kohm resistor.
Is this a normal behaviour? I didnt found any details in the datasheet. All other functions are working according to design.
