Our customer has looked for 12.7V input to 0.6V/3A output DCDC converter in strict power on/off sequence and we proposed TPS62903 is the best.
While we reviewed the datasheet, we have a question how TPS62903 can drive 0.6V/3A output from 12.7Vinput voltage. Because the datasheet specify 50ns minimum on time and selectable 1MHz or 2.5MHz switching frequency. Even if we can select 1MHz switching frequency, the on time in this case is 47ns which is less than minimum on time 50ns.
Could you let us know how TPS62903 can drive 0.6V/3A output from 12.7V input voltage.
