Strange the part number TPS62172DSG has not been detected anyways I am using TPS62172DSGR in my project.
My project has a charging IC with over-voltage protection and was thinking to use TPS62172DSG for converting battery voltage to stable 3.3v.
After reviewing the datasheet I got to know that TPS62172DSG has an under-voltage cut-off UVLO inbuild at >2.7V.
So my question is as followed:
1) once voltage is below 2.7V it will enter in UVLO and at this point, my load will get 0V or there will be some voltage load will see at Vout?
2) Can I avoid using additional low voltage protection circuitry in my PCB as TPS62172DSG has UVLO? To reduce my BOM cost.
3) with enabled low Vout will be 0V or it will have some voltage on it?
Thank You for your help.
