TPS1HC30-Q1: How is its nFAULT released from OCP event?
Part Number: TPS1HC30-Q1
Hi team,
How is its nFAULT cleard (Hi-Z) from OCP event? DIAG_EN pin is high and Latch pin is floating.
Are the only way clear nFAULT "pull down EN" or "overcurrent condition is released"?
Ochi
  • Hi Ochi-san,
    Yes you are correct that pull down "EN" which shuts off the part, or the overcurrent condition is released will be two ways to clear the fault. Also pull DIAG_EN low will release the FAULT as well.
    Please let me know if you have additional questions.
    Yichi
