LMR33630-Q1: Output Capacitance equation
Part Number: LMR33630-Q1
Other Parts Discussed in Thread: LMR33630
Hi all
I found the LMR336 calculator from TI, I have checked from datasheet, but there is only one equation for Cout :
And when I try to do manual calculation, the result is different with calculator one.
I would like to know what formula is used for Calculated Output Capacitance and Calculated Minimum Output Capacitance in this calculator:
Attached are the datasheet and calculator that i found
8422.lmr33630-q1.pdf4011.snvr484.zip
Thank you :)
