Good day
I am currently facing an issue with my BQ79614PAPRQ1 BMS IC,
note, I am only using 8 cells, VC* and CB* 9 to 14 are connected to VBAT.
The cell balancing works perfectly for cells 1 to 7 but the external FET controlling the balancing of cell 8 does not turn on fully,
it partially turns on after the rest of the pack reaches its VCB_DONE_THRESH value.
I have also noticed that the FET stays on (partially) even after it reaches its VCB_DONE_THRESH. This takes much longer compared to the other cells,
I have attached the Cell balancing network,
Please could you assist with possible solutions or areas to explore.
