Hi, Team
Hope you are doing well!
My customer want to use our TPS92682-Q1 in CC mode to supply position light.
The minimum output current required is 6mA.
The input voltage range is 9~16V, the output voltage required is 45~50V.
What is the minimum current that our device can output?
How should it be calculated? What factors will be affected?
Is it okay to just use the formula below?
Thanks & Best Regards
Jeff
