TPS568230: The Acp and Ts of TPS568230
Part Number: TPS568230
Hi Team,
In the Application Report, I don't know where the value of Acp and ωRI  come from. Can you give me a hint? Thanks.
Charlie
  • Hi Charlie,
    Acp is a gain of internal compensation. wRI is the angular frequency of internal compensated zero.
    D-CAP3 is with integrated compensation. Those values are normally fixed after you select a switching frequency for a D-CAP3 converter.
    I don't know if you have read the part I app note SLVAF11. It has more detailed introduction about the internal compensation.
    Andrew
  • Hi Andrew,
    Thanks for your quick reply. Yes, I have read the app note SLVAF11.
    A ripple generation circuit is integrated. Will the datasheet give the resistance and capacitance of the ripple generating circuit, or directly give the location of the zero point?
    I searched the datasheet again, but I still didn't find the value of Acp and ωRI .And I only found explanations about compensating the zero point. Did I miss it when looking at the datasheet? Thanks.
    Charlie
  • Hi Charlie,
    The internal compensation circuit is confidential.
    Compensated zero is given in some datasheet.
    A more common method now is to directly give recommended bom range including L, C and feedforward cap in datasheet to ensure converter stability. Customer could use our part easily following the recommendation.
    Andrew
  • Hi Andrew,
    Thanks for your support.
    Charlie
