Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS2384: Reference Design File
Part Number: TPS2384
Other Parts Discussed in Thread: TPS23861, TPS23882
Hello E2E Experts,
Good day.
It looks like the reference design files for the TPS2384 evaluation module are missing online.
I found some datasheet that includes PCB and schematics however we would greatly appreciate it if you can provide the files themselves.
We are evaluating the use of the TPS2384 in one of our multicamera setups and this would speed up our development.
CSC
  • Hi CSC,
    TPS2384 is an old PSE device compliant only with 802.3af standards, for new designs we recommend using 802.3bt devices such as TPS23882(B) in order to meet the current specifications set by IEEE. You can also use TPS23861 for 4 channel systems, however this device only meets 802.3at specifications. For TPS23882(B) the EVM design files are available on ti.com.
    Let me reach out internally for the TPS2384 EVM design files if you're still interested!
    Thanks and Regards,
    Raymond Lin
