TPS715: TPS715
Part Number: TPS715
Hi Team,
There is a part no. TPS71550DCKR for which I need clarification from your end.
Please find the attached datasheets and as you could see in the functional block diagram(fixed version), in the older datasheet it's a P-MOSFET and in the latest datasheet it's NMOSFET.
Could you please let me know if this an error or if it's a change then kindly share the reason for the same.
Ivona
