The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS629210: VSET internal voltage divider versus FB external voltage divider
Part Number: TPS629210
What is the intended usage of the VSET internal voltage divider? Just one less external component required?
Are there any obvious pros/cons I am missing? It seems to function nearly identically to the FB external voltage divider mode.
The only difference I can find is Table 8-1 from the datasheet (below) indicates that dynamically switching modes between Auto PFM/PWM and Forced PWM can only be done when using external FB.
Is this the only consideration?
Thanks for your time
