Part Number: TPS62060
Hi team,
In an application that input voltage decreases slowly, I found the undervoltage lockout function kept getting triggered with the waveform shown as below
The purple line shows the output of TPS62060.
I think this should be fine regarding the reliability and it doesn't seem like this would damage the IC, but still I think rapid change at output voltage might cause other issues such as greater EMI.
What would be the recommended way to solve this issue? If adding a reset IC like below is recommended, could you please advise a specific part number for this case?
