LMR36015: Spread Spectrum Available on industrial part?
Part Number: LMR36015
HI there,
Does the industrial version of this part have Spread Spectrum? It's in the splash summary but I couldn't find it anywhere else in the datasheet? Looks like it could only be on the automotive part?
Thanks!
    Yes it is a feature for the industrial version, as mentioned on the cover page of the ds:
    Youhao
  • HI Youhao,
    Thanks I was confused because its on the summary page, but not mentioned anywhere else in the datasheet. The Q1 datasheet shows it as an option and talks about it in the spec portion of the datasheet. So I wanted to make sure! You are saying that it is in the industrial version too even though its not mentioned in the specs?
    Thanks!
    Sorry that I took it for granted by just reading the DS cover page.  After your above post, I went to check with our team members who were more familiar with the part, and it turns out that spread spectrum is turned off in the industrial version, so that line in the datasheet is a mistake, and it should be deleted.
    Thank you for your diligence which helps us to contain the mistake from causing more "damage".  We will update the datasheet soon.
    If you want to use the spread spectrum feature, you will need to use the -Q version of the device.
    Also please note that, only Q devices with an "S" in the OPN have spread spectrum.
    Youhao
