Hello team - is the gold finish for the TPS82150SILR ENIG or electroplated? If it’s electroplated, then would you please send me the thickness range or max. thickness for the gold.
Thank you!
Thank you!
Hi Alex,
What do you mean ENIG or electroplated? Is it lead finish material? What is the reason do you need this information?
Nancy
Hi Nancy,
Did you locate the information? Yes the question is about the lead finish material. Contact your qualification/ reliability engineering department to confirm. Customer requires the information due to the nature of their end application.
Hi Collin,
Here is the TPS82150 bottom layer surface finish information I got from team.
Hope this helps,
Nancy
