My customer is looking for a two channel buck to supply C2000 MCU. It's 12-to-3.3V application. MCU has two grounds - AGND and DGND - which connect to each other thru a 0ohm resistor for noise minimization. I'm wondering if PGND1 pin #4 and PGND2 pin #13 can be connnected to different node. They want to connect PGND1 pin #4 to MCU's AGND and PGND2 pin # to MUC's DGND. Technically AGND and DGND has the same voltage level because of short tie or 0ohm connection but still they're separated in PCB.
Below is current customer schematic. What they want is to generate DVCC_3.3V and AVCC_3.3V separately.
Please advise.
Sincerely,
Ella
