Hi expert,
In the SOP project, my customer found that UCC21520 has a case of abnormal output. Check that the low-voltage side is working normally. The high-voltage side customer has measured the auxiliary power supply current is normal(NO big current), VDD, VSS impedance is normal, but the output is always low, after ABA, the fault no longer exists, and now you need to provide the following help:
1. Potential reasons that may cause the output to have no waveform
2. The withstand voltage parameters of the internal diode
Any idea pls let me know, thanks.
