Other Parts Discussed in Thread: TPS7H4001-SP,
I did not find the "WCA model guide" referenced in the example worst-case analysis PSpice testbench, I'm wondering if there is one available for this part similar to this: https://www.ti.com/lit/ug/slvuc15/slvuc15.pdf
Also, I notice that the TPS7H4001-SP WCA model includes both a TID and AGING parameter, while the TPS7H1101A-SP WCA model only includes a TID parameter. What does "AGING" model and why was it not needed for this part?
Furthermore, the TPS7H4001-SP WCA model includes tolerances for error amplifier Gm as well as output stage Gm, while the TPS7H1101A-SP WCA model only includes a tolerance for output stage Gm. Is it really not necessary to consider the variation in the error amplifier and its effects on stability?
