UCC21710QDWEVM-025: Output switching waveforms test
Part Number: UCC21710QDWEVM-025
When the input and output switching waveforms test was performed with the instruction on https://www.ti.com/lit/ug/sluubx2b/sluubx2b.pdf?ts=1680578620878&ref_url=https%253A%252F%252Fwww.ti.com%252Ftool%252FUCC21710QDWEVM-025, LED D10 becomes dark, but LED D11 is still "Light" when the function generator is turned on, and there is no output switching. How can I check the issue on the board? Before that testing, it was confirmed that power up and bias supply voltages test is normal.
Thank you for your support in advance.
