Part Number: LM5108
Other Parts Discussed in Thread: TMUX8108,
Dear,
Is it possible to use this gate driver as a single channel gate driver?
We have the following situation. We need to act as an electronic switch between a high impedant input and a relative low output impedance. I cannot use a relay (100000 cycles won't be enough). So I was thinking to use a N-channel mosfet, but with a gate driver to boost the signal above the voltage at topside of the switch.
General idea of our current problem:
The 5MOhm (or higher) is to keep HS in a defined area when the switch is open.
General idea of how we want to solve this:
Or do you suggest a different kind of solution? The only other kind of solution i was thinking of is TMUX8108 and only use one channel.
Jan
