TIDM-PSFB-DCDC: Secondary side rectification
Part Number: TIDM-PSFB-DCDC
TIDU248 uses a center-tap synchronous rectification for the secondary. can you tell me what is the application of D4/D6 in the schematic? how does it work?
Best Regards
Toktam Khani
  • Hi Toktam,
    It is a passive snubber to attenuate ringing on the SR MOSFET drains. When the SR FET drain voltage flies up at the turn off edge of the SR, the diodes provide a path for the leakage energy to be transferred into C1 and limit the max voltage stress seen by the SR FET.
    Chen
